Body mounts | Ford Explorer Forums
Body mounts
Brad7406
Washington
2003 Ford Explorer Sport
So I have a 2003 ford explorer sport and I need to replace the body mounts I have been looking online. I can find a bunch of mounts for the sport trac but not the sport. Has any one found good cheap mounts I am not looking for rubber ones I want the poly mounts so once it is done that is it. Thanks for all your help!
hmmm your sport should use the same body mount kit as the 4 door explorers, not the sport trac, as the trac has a bed and the bed is not mounted on body pucks
I would order a body mount package for a 4 door explorer, like 2000 or 2001, should be the same as your sport, or at least similar enough to get you the parts you need.
I used that same kit on mine...
Thank you for your answers everyone I looked for awhile before posting never seen the mount you had a link to. They look like the ones I need so I ordered them also the instructions looked very clear on the website should be fun.
Use an impact wrench after you heat them with a torch. Ford loctite is a mother on the bolts…
Yeah I learned that when my 1/2 inch impact locked up on the front bolt after removing the top nut. I had to use a 3/4 inch impact I have laying around that made a huge difference:)
