Nicaraguense
- August 19, 2003
- Jonesboro, AR
- 2000 4Dr XLT 4WD 4.0
I was off roading the other day and got mud, muck, and pebbles in my brakes, I took them apart to clean them out, fix the noise and hope it wasn't a bad bearing. When I put it back together I did a sloppy job and learned my lesson. One of the bolts holding the caliper to the spindle fell out and began to click when braking, and rub the rim when backing up
I just put a bolt in today. It was a bolt I got from Lowe's. It wasn't a caliper bolt (obviously) none of the parts houses open on Sunday had one. It was a grade 8.8. Is that a hard enough bolt for brake calipers?
