brake drums | Ford Explorer Forums
brake drums
stoneyj69
palmer, ak
1994 explorer xl
has anybody else had problems getting them off?
Have you "retracted" the shoes? You can reach through a small hole near the bottom of the backing plate with a couple of screwdrivers and rotate the adjustment wheel to retract the shoes.
Mine were a major pain to get off. I ended up using a rubber mallet for quite a while to loosen them. My Honda was designed so much smarter. There are two threaded holes that you screw bolts into, and the bolts push the drum off. I wish the X had the same set up!
