brake lamps not working | Ford Explorer Forums
RogarXtwZ
the pedal switch is working but I dont have a fuse diamgram to see if its a fuse? and does anyone know if brake lamps bulbs are seperate from turn signal bulbs?
Pretty sure on that generation they are the same, so everything runs through the turn signal switch.
Stoplamps are #1 in the fuse panel under the dash on the driver's side:
91-94 X Schematics / Diagrams:
http://www.explorerforum.com/forums/showthread.php?t=232576
The brake and turn signals use the same 3157 bulb, and they use seperate filaments from the tail lamps, so if the brake/signal lamps don't work but the turn signals/flashers and tails do, it's likely the brake switch or something else. It's also very rare for both brake/signal filaments to go out at the same time, but it is possible. Be sure to get quality bulbs from Sylvania or Philips and they will last long and burn bright.
You're crazy, the two filaments are for tail lights and turn/stop lamps.
