Brake Light Issues After Assembly Replacement | Ford Explorer Forums
TheZark
Washington Missouri
2014, Explorer Limited
I have a 2014 Limited and am out of ideas for my brake light problem.
A few weeks ago we had the water in the assembly of the driver side taillight. The LEDs flickered for a few days but then went completed out. I replaced all bulbs and then replaced the entire driver side assembly. The reverse lights and blinkers work fine now. The LED ring of tail lights shine when turned on. However the LED ring does not get brighter when the break is depressed. Also the 3rd high mount brake light does not light up either. I have replaced the high mount light, the brake switch, and any fuses that I can think of.
I am out of ideas on why the brakes will not light up when depressed.
Anyone have any ideas or thoughts?
Welcome to the Forum. :wave:
Have you checked all applicable fuses?
I have replaced any fuse that I can think would be affecting this brake lights.
