Brake problem | Ford Explorer Forums
Brake problem
cw212010
Explorer
Hi all,
New bearing, rotor and pads on this wheel around one month ago. In the past few days I've had a squeak when turning left past the 12 o'clock position. I assumed it was to do with the fact the outer rubber CV boot has a tear in it however I've looked and almost an inch of the rotor has been getting worn away.
Can anyone suggest from the attached photographs what could be causing this? I had thought the metal clips on the brake pads? It's too hot to remove the wheel at the moment.
754436065960886272
https://twitter.com/cw212010/status/754436065960886272
Update: Disassembled wheel to find bolts holding calliper were loose.
