Aloha Ranger 94
- August 8, 2006
- Mililani, Hawaii
- 1994 XLT Extended Cab 4.0
I am experiencing an issue with my brakes that is getting progressively worse. It started off with a simple pad change on the front wheels. When replacing the left pad I noticed the rotor was shot so I replaced it also. After about a month I noticed the brakes would drag occasionally on the way home. On one occassion the left front brake locked up and by the time I got home the wheel was smoking. Then when I applied the brakes the truck pulled to the right. So I figure the caliber was shot so I replaced it but I am still experiencing the problem. My next step was to replace the master cylinder and bleed the whole system. This did not fix the problem and when I tried to bleed the back brakes I could not get any fluid to the rear brakes. The repair manual states to bleed the RABS before bleeding the rear brakes but I cannot see where to bleed this system.
Any thoughts?
Any thoughts?
