Rcflyer330
- March 23, 2014
- Michigan
- 2010 Ford Explorer XLT V6
so to start its a 2010 ford explorer v6 98k miles. here is what is happening i took the car to the dealership to diagnose my squishy breaks they came back with front brakes and rotors needed to be replaced. i decided not to have the dealership do them and did them myself. after i replaced them the brakes did feel better but is still very soft. (dealer said rear brakes where fine) the last time i did the brakes i did bleed them and changed the fluid.
any suggestions?
second problem that has been getting worse something in the rear suspension is squeaking basically if you shake the car it will make the noise. i have checked the sway bar links that is not the cause. the noise is coming from near the rear diff i am thinking its either the control arm bushings or the sway bar bushings on the frame of the vehicle. any other things that could be and how would i test those two bushings?
any suggestions?
