bam_bam1ca
- January 7, 2007
- kitchener, Ontario
- 1998 XLT, 1970 Olds 442
Good evening.
I am experiencing an intermittant problem with my brake warning light. The dash light will turn on intermittantly and go out. I have checked the fluid level in the master, and it is full. The pedal is firm and does not bleed down. The brakes and anti-lock system are also working fine. I have not touched the emergencies, so I am not suspecting that switch. Sometimes the lamp will come on bright, and other times it will be dim, or dim and flickering. This sounds like it may possibly be a ground problem. Has anybody else experienced this problem?
