rvaedge
- March 30, 2005
- Richmond, VA
I have a couple of questions actually, and I've searched all over with no clear answer. I have a 1997 AWD.
First are my brakes. I recently replaced the rotors and pads all the way around the x. There has been a chirping noise (first I thought it was a bug in my car) that happens only when I apply the brakes. It is coming from the rear. Could it be missing anti rattle clips or would the chirp only happen when I was NOT applying the brakes if that was the case. I've read stuff about maybe cleaning and lubing the caliper pins, or the rear of the brake pads. I'm not sure what caliper pins are or where I would put lube on the brake pad itself (pictures would help if anyone has them). Anyways, its really annoying, so any suggestions would be greatly appreciated.
Also my brakes dont seem to be that responsive. I have to apply more pressure than it seems I should have to to get my car to stop, and sometimes I'll find myself creeping forward at a stop light and have to press even harder. Should I try adding brake fluid or even bleeding the brakes or maybe its a the brake booster? I drove my friends new jeep liberty and it brakes at the slightest amount of pressure, while mine takes a lead foot to stop it. Any ideas.
Sorry for the long post its just I really want to get these things fixed asap. Thanks a lot guys
