rama1200
- July 1, 2005
- Jackson, MS
- 2004 explorer xls
morning, all...
I got an H3, 4300k h.i.d. kit... and a set of those driving lights from walmart (those that have the blue glass)... also, I had previously installed a pair of projector fog light (also cheap) from autozone....
My idea was to install the driving light using the same wires as the already-installed fog light and have them all fire up with the same switch... when I installed one of the driving-lights (with the h.i.d. already in it), it all worked fine... but when I ran the wire to the second h.i.d. modified driving light, it started blinking really fast, and then blew the fuse that came with the foglight kit (30 amp round glass fuse)....
Then I replaced it and did it again.... so I tried to fire them all up bypassing/bridging the fuse... that worked... but it seemed to me that the connection was getting hotter (I don't remember before how hot it got - if anything at all).
Then I replaced that fuse of the fog light with the one tht came with the driving light (15 amp plastic with metal M-shaped wire inside), and just left the driving light (h.i.d. powered) and unpluged the fogs... that worked ok too...
I really would like to have both fogs and driving lights on the same switch... originally, they both came with H3 55w halogens (fogs remain the same, driving lights are now h.i.d. powered).
is this possible to do with the wires/fuse that came with the cheap kits from walmart? or would I need a strong/better wire, etc.?
or better run separate wires to separate witches with seperate fuses?
is the wiring/fuse that comes with those walmart kits enough to run an h.i.d. kit (if not what do you guys suggest?) or will the kit "melt" the wiring?
I'll post pics later when I fix all my issues.....
thanks
thanks
