joefnh
- April 30, 2005
- New Hampshire
- 03 XLT
- Callsign
- KA1DGB
I have a 03 4.0L 4x4 that I have had an ongoing issue with breaking the wheel studs on the rear wheels. It started after I had one break when the local tire shop was rotating and balancing them about 1 year ago. I had replaced that one wheel stud and after that had others break. At that point I assumed that the studs had been weakened by an over zealous employee with the air gun.
I had at that point decided to replace all of the studs on the rear with factory replacements. When replacing them I was careful never to exceed 90 foot pounds of torque and never used an air gun on them. I had re-torqued them after replacing the studs every 300 miles again never exceeding 90 foot pounds for the next 1000 miles. I have always run factory size 16'" tires
Since that first 'mass replacement' I have had 3 additional occurrences of the studs breaking, each time when one would break I replaced all 5 just to be safe. It has happened on both rear sides. This truck never sees rough driving, it is my DD and only sees simple highway commuter traffic on smooth roads
It should also be noted that at about the same time at the tire shop mishap I had replaced the rear brake rotors during a brake overhaul. I have even had my torque wrench tested for accuracy
Any ideas -- this is not only baffling but quite dangerous.
--Joe
--Joe
