Broken Lower Intake Bolt | Ford Explorer Forums
malohnes
SE Alaska
'91 xl m5 4x4
Tried searching, but didn't find much...
While tightening down some loose LIM bolts near the back, driver side (cylinder #5, I think?) I snapped one of the 10mm bolts off. It is still a bit loose and I have leaking oil and coolant causing my Eploder to run less than perfect. Is this a simple EZ out routine? Any suggestions?
Can I use some common metric bolts of the appropriate size at my local hardware store or do I need bolts from Ford? I didn't locate any at Rock Auto.
Thanks for your help!
Common bolts from Home Depot will work.
Grade 5
Ryan
Thanks Ryan, thats what I wanted to hear.
