gatzdon
- July 17, 2007
- IL
- 2000 Exp XLS 4WD V6 OHV
Background Info.
2000 Ford Explorer 4WD 230,000 miles V6 OHV (X for engine code)
Problem;
Last week, my wife commented that the vehicle was vibrating. On Thursday, I test drove it to put some gas in it and really didn't feel much for vibration, but it did run a little rough. I figured it was due for a tuneup and planned on doing it this upcoming weekend. On Saturday, she told me the check engine light came on. Sunday, I pull the OBD codes and get a single code P0303 (misfire in Cylinder 3). I have her drive a different vehicle for work yesterday and park it in the driveway until I could get to it.
Yesterday, I pick up plugs, wireset, and coil pack (just to have on hand if I do need to swap the old one out). I start changing the plugs and I can see the positive electrode tips were worn down. I'm assuming that this is going to be the cause of my misfire until I get to cylinder 3 where I find the entire positive electrode is snapped off from about ½" inside the plug (see picture).
http://i195.photobucket.com/albums/z106/gatzdon/BrokenSparkPlug1.jpg
I'm assuming it cracked/fell off when she first reported the vibration. The vehicle was probably driven for almost another 100 miles before I parked it and told her should couldn't drive it anymore.
My question to you guys is this. How would you proceed?
The engine has 230,000 miles on it. I can't see it really being worth the money and/or effort to pull the engine apart to take the head off and look at the cylinder and piston. I figure if I take it that far apart, might as well get it rebuilt. Since the engine was running decent prior to this incident, I would like to weigh all my other options first.
I assume there are two possible scenarios here.
1. The electrode is still inside the cylinder and putting a new plug in to start the engine could still cause serious damage to the engine. I plan on picking up a 24" lighted boroscope from Harbor Freight Tools in order to look inside the cylinder. I will rotate the crank until the piston is at the low end. I know this won't allow me to see if anything is embedded in the cylinder head, but will allow me to see if there is anything still in the cylinder loose. I'm assuming at this point that the porcelain has already been pulverized and done what ever damage it's going to do to the cylinder walls. If I find the electrode is still in the cylinder, hopefully I can remove it with a rare earth magnet. I also believe that if it's still in the cylinder that there's a very good chance that the valve seat has not been damaged.
2. The electrode has already been blown out the exhaust valve. In this scenario, there is little risk of further damage to the cylinder, but the cylinder walls/piston/valve seat may already be damaged. I realize that even if I don't find the electrode in the cylinder with the boroscope, there is a chance that it is embedded in the cylinder head and could still come loose at a later point in time. If the electrode was blown out the exhaust valve, there is probably a good chance that the valve seat has been damaged and a remote possibility that the valve itself has been damaged depending on how much porcelain was still on the electrode when it blew out.
I know I've written a small novel here, but I'm trying to think this through thoroughly before I even consider taking the risk of starting the engine again or go through the trouble to remove the head.
So as of today, My current plan is to
= Buy the boroscope and look in the engine.
= If I see something, lower a rare earth magnet. Don't know if this will work as I don't know how much steel or nickel is in the positive electrode. I know there is nothing magnetic at the tip, but since it broke off so far into the plug, I'm hoping there's some steel or nickel that was used and is still attached. If I can see the electrode in the cylinder and it's not magnetic, I'll invest in a claw to reach in and grab it.
= Do a compression test to determine how much damage has already been done.
I'm posting to see what other suggestions/approaches anybody here might have on how to proceed.
On a side note, I've been searching via google for info on this and what other people have done, and it would appear that in almost every case of an electrode breaking off in the cylinder (positive or ground), it was a bosch plug involved which is what this one happens to be.
Problem;
