bronco II 4 link need help | Ford Explorer Forums
90minibronc
brunswick ohio
90 bronco II
Hey Ya'll i am pretty new to fabricating things, been wheeling with friends for a few years but just bought a 90 bronco II for $300. couldnt beat it good truck for the money. Anyways on the first day out with a jeep buddy i broke a halfshaft in the twin i beam front, and want to go with a 4 link straight axle front with like a Dana 30 or 44 axle. My question is what i would need to do in order to build that four-link and what math is needed? this is going to be done in my garage would rather build my own. Any info would be very helpful. Thanks
you need the search feature! If you are dead set on using a 4 link setup (more likely a 5 link since it has a trac bar for the front axle) then you have alot of research to do before you build anything.
Best place to start would be on this site, Pirate 4x4 and the rest of the internet.
There is alot to consider, not only the geometry and proper setup but also how to make it fit under your BII.
