jgilbs
- October 29, 2002
- Naperville, IL(home)/Iowa City, IA(school)
- 92 Eddie Bauer
building new switch panel/console
Hey all,
I am done with school for the semester, so i have like a month of nothing to do. During that time, I figured it would be a good time to build a new center console for my truck(not replace the stock one, just extend it all the way to the HVAC controls) Since I am a firefighter and a geek in general, I have loads of equipment I need to mount. I have my Arrowstik control, a scanner, a CB, loads of switches, and a 120v receptacle I would like to incorporate into it. Also, since I will be adding a lot of electronics, I thought inside the console would be a good place to run a 4ga wire from the batt to a fuseblock inside the unit. I am buying a new 220v welder, so I will prob use 3/16" steel and paint it flat black when I am done. Does anyone have any experience or tips for me? I want to basically use 2 vertical steel plates on either side of the trans hump, and add a lip to them at the top. I would then just use custom fabbed "faceplates" to attach to the top, which would double as a mounting point for all the equipment. I am not sure how to mount the equipment on the faceplates though. I am thinking of taking the rectangular facepieces and cutting them so the cut looks like an H on its side, then folding down the 2 flaps it creates. I would then drill holes in the sides of these "flaps" so I could bolt them to the radios like their brackets attach.
Sorry if im not clear on what i want to do, but any advice is appreciated, and i will have tons of pics after i start so i can share with anyone else doing anything like this.
Hey all,
