Disco 2. the bar os from Symbar, bought it on ebay for £30. there are (or were) loads of them, the size and shape is good for the A Bar but i don't think the full wrap around ones would fit
The brackets were fabricated in 25mm angle, two come up straignt from the bar at 45deg and bolt on to the chassis rail behind the bumber (don't need to take the bumber off) I think these are the normal holes for the OEM bar.
The second set of brackets are attached to the end of the bar at each end and again go to the chassis rail either side of the radiator. Solid!
if you compare the two pictures you will see my Landrover one goes under the front and the pucka explorer one does not
cheers
Jim
