Bull bars | Ford Explorer Forums
Bull bars
Neil Tucker
High Wycombe
97 4.0L SOHC Met. Grey
Anyone know where I can get a set of bull bars for my 97 explorer?
Tally ho!
Neil
if you can weld some brackets, the a frame from a Landrover discovery is a good fit, or you can wait an age for an explorer one.:)
That's a nice idea, so, the actual bull bar is from a disco, yes? (what series?) then you just weld on the necessary brackets yes?
Neil
Disco 2. the bar os from Symbar, bought it on ebay for £30. there are (or were) loads of them, the size and shape is good for the A Bar but i don't think the full wrap around ones would fit
The brackets were fabricated in 25mm angle, two come up straignt from the bar at 45deg and bolt on to the chassis rail behind the bumber (don't need to take the bumber off) I think these are the normal holes for the OEM bar.
The second set of brackets are attached to the end of the bar at each end and again go to the chassis rail either side of the radiator. Solid!
if you compare the two pictures you will see my Landrover one goes under the front and the pucka explorer one does not
cheers
Jim
Ay up Jim,
Mine were second hand off ebay and were advertised as coming off a Land Rover. Don't know which model though.
Kev.
they look like the real thing, wider than mine
Hi Guys
just like to say nice also Kevin p were did you get the lighting pod on top from as i have been looking for something like that to stick on top of my Exp
thanks
Paul
Ay up Paul. I honestly cant remember where I got it from. There is one on ebay, number 180529708717. I got mine from England though.
www.formula4x4.co.uk have got a nice shaped one.
Mine took alot of work with a heat gun to bend it to the shape of the Explorer roof.
Kev.
ebay 360187570006. They are a universal fit
Big thanks for that
look like an after xmas gift
