Knox5.0
- March 5, 2010
- Knox, Tn
- 98 XLT 5.0
I got home today after running some errands and i notice coolant dripping pretty fast under the front of the car. I open the hood and everything up top is dry. Both upper and lower radiator hoses are dry. So i crawl underneath and its leaking on the mid to lower right side(passenger side) of the radiator above the drain plug. I cant actually see where the coolant is coming from but the entire lower right corner of the radiator is wet.
I did check the drain plug itself and tightened it as much as i could. Wiped everything down and started the motor. After about a minute it starts dripping again. It seems to be leaking above the petcock somewhere. Im going to remove the radiator shroud tomorrow to have a better look because the leak is somewhere behind it. Is there anything else behind the shroud on the right side that could leak other than the radiator itself?
How bad of a DIY is it to replace the radiator?
