You can also take it apart and attempt repair. Put new grease on the contacts, sand them down. I repaired one on an old Ford, but it depends how much your time is worth :lol:
Just did this to mine which started buzzing on the right turn signal.
It really wasn't any extra time. Once you have the assembly out, there's only 5 screws holding it together, T10 if I recall correctly.
Lay it flat when taking the screw-side cover off carefully and no parts will come flying out. Next I took a cotton swab with brasso (brass polish) and polished the contacts for a couple minutes, then came back with a clean cotton swab and dry paper towel and wiped remaining residue off.
Smeared a coat of dielectric grease on the contacts, put it back together, and 5 minutes later it was ready to put back in... probably less time than hunting down the best deal for a new one and ordering/tracking/receiving/inspecting it.
Before I had taken mine off, I mean a few months ago, I had taken the end cap and screw off, to take the rotating portion for the wiper speed off and clean grime off. At that point I had lost the detents (notchy feeling) for the wiper speed and couldn't figure out what happened.
Recently I figured that out. There is a spring with two brass end caps on it that is in the turn signal shaft right behind that rotating wiper speed adjustment ring. If you take the wiper speed ring off, odds are it will come flying out and I hadn't noticed that it did that. The spring and caps are perpendicular to the length of the turn signal stalk, across the diameter of it. They notch into molded sections on the inside diameter of the wiper speed adjustment ring.
One other tidbit I realized about pulling that multifunction switch out is that you don't have to take the lower dash trim panel off if you tilt the steering wheel down and are patient manipulating the cover pieces off and on. It doesn't speed the repair up a lot (couple minutes maybe) but does avoid getting down under the dash to work, everything else can be done standing next to the driver's seat.
