dillling
- December 19, 2005
- maryland
Ok searched,read for 2 days I found the parts I need please check me
2.8 c5 bell housing and flexplate and spacer plate
rebuild c5 with c4 valve body, use c5 toque conveter
I going to try too make colum shift work,but will grab floor shift just in case
going to get lokar kickdown cable
ok the stuff I am not clear on do I need to get bronco 2 transfer case or can I use the eletric shift t-case I have, I think I can use it but just want to make sure.
Also if some one has done this swap to they have the drive shaft length for a 94 4 door model. That way I could have them built before truck is on my lift and have this project done quickly.
any snags you guys can think of would be great is you point them out
wiring is not going to be a promblem,
