CAGE Radius Arms (for SAS) | Page 2 | Ford Explorer Forums
Thanx James, this is what I needed to know, have that at my disposal so now I can decide what I want to do about my RA's.
Jeff - :navajo:
james t said:
What you're saying makes sense, but its not that big of a deal unless you're running a ton of lift. They're not at much of an angle with the typical 3.5" or even 5.5" spring.
Yep, I agree. And then If you did have a ton of lift, the brackets at the frame would have to be so low that it could be a problem in its self. But since I'm building them and have them allmost done. I'll at least try to get the frame end as close to level as I can. Maybe the rubber bushing at the frame may take up some of the force if not at a level plane.
You've probably have allready seen the site below. But might just have some useful info for someone.
To get back on subject the ones in this thread allmost look like the ones I have. I will also have some tire clearance built into them, wether bent rod or cut and turn stamped metal part along with some down turn also. Then box in. I don't think the price is that high. Looks well made and a lot of thought and tooling up went into it.
http://www.dezertrangers.com/cgi-bi...=2;t=28267;st=0
Oops, seems its not letting me go to the RA post.
