ihpj
- April 2, 2011
- 1998 UK SOHC Explorer
Guys, I am in need of the above item, with one calliper sliding pin please. Any chance anyone is breaking an Ex. and has these parts available please?
I replaced the front pads on my Ex. today and noticed uneven wear between the axles. On the N/S/F the inner pad was worn down to around 3MM but the outer was 5MM - both evenly worn across the surface. O/S/F inner pad down to 4MM but the outer pad nearly worn right down to the backing material!
Had a quick look, nothing obvious; these were genuine EBC standard brake pads (so quality and manufacture not an issue). Spoke with Howard and and he opined it was likely to be seized slide pins.
Checking the N/S/F the upper slide was OK but the lower was seized solid
On the O/S/F both were moving, but not as freely as would be expected. Of the ones that I could remove, I did so; cleaned them with emery paper and, as I only had WD40, used liberal amounts of that (sprayed some into the pin hole as well) and replaced the slide pins - they now were sliding beautifully and freely. Unfortunately I couldn't unsieze the seized pin but at least I was right to change my pads when I did!
Since I don't think I will be able to remove the sized slide pin, on Howard's suggestion, I'm going to replace the entire calliper carrier. So if anyone can help, please let me know!
