Cam Chain Tensioners | Ford Explorer Forums
cshuman
Vista CA
'97 Eddie Bauer Eddition
So I just got a 97 explorer eddie bauer v-6 sohc, and I've heard that a common problem with this motor is the cam chain tensioners break and can cause engine damage. Is this common? And does anyone have a diy up to replace those parts? Or know which parts I need to replace this? If this is a problem I'd like to get in there and change those out as some preventive maintenance, before I lose the motor.
It's pretty common after 90k miles. I lost my first engine to it around there. You'll most likely have some warning, though. Mine started running progressively worse for at least a year before it went. I had no idea why until I found this forum (after the damage was done).
People generally will start hearing the chain rattling around in there. You hear it especially under load and at around 2500-3000rpm, or when cold-starting the engine. It sounds like engine knock at first and can eventually make your engine sound like a diesel engine.
There's several different fixes for it. If you take it to a dealer, they are generally going to do the 00m12 mod which involves replacing the tensioner on the driver-side timing chain. This, however, still leaves the back tensioner and the jackshaft tensioner vulnerable. It might buy you a little time, but I doubt it's going to add 100k miles to the engine or anything.
To really do it right, you need to pull the engine and replace all the chains, sprockets, tensioners, and cassettes on all three chains. I think the cost of the parts is around $200 and you need a $150 dollar tool to hold the camshafts in place. There's several diaries posted on here with pics and here's a blog that has the step-by-step w/ pictures at the bottom. Unless you do the work yourself, I doubt you could find a dealership that would do this for you and even if they did, the cost would most likely be unbearable.
Keep in mind you can still find relatively low mileage sohc engines (allegedly 50k miles) for $700-1000. I paid around $2000 for one installed and so far it's bought me about 50k miles. I haven't heard the notorious death-rattle yet, but my second engine has recently developed a pretty rough idle so I'm starting to get nervous. I'm considering pulling it soon to do the mods.
ok cause the one I just got already has 170K on it, every once and a while itll sound like a diesel, I didnt think anything of it because the guy that had it before me hasnt run it I was thinking it just needed some tune up work. Anytime it does make the noise I just kill it and restart and it goes away, I assumed it was just running rough. It sounds much better after the oil change but this worries me a little. I have yet to register it so I havent driven it much yet so I don't know, could be my imagination.
I was unaware this was an issue untill i read this thread. I guess im lucky. I have over 450,000KM on my motor. Still runs like a top.
95 Eddie Explorer 4.0
