dreamr said:
I am not positive on the pre 94 engines, but i would assume so as there needs to be some sensor to monitor the cam position on a distributorless ignition system. However I do not know as I have never looked at a early OHV.
The thread is in regard to a 4.0 from 96. It does have the CMP. It is attached to the top of what one could say, looks like a distributor, in a pretty general sort of way. That drive is on the rear side of the lower intake manifold, for the OHV 4.0, 3.0 and 5.0, they are all somewhat similar. The 4.0 SOHC is a somewhat different story, for a different thread.
pj-The last engine I worked on, well, prior to my 92 3.8l supercharged (lol)superpoop tbird, was a 383 wedge without a single emission item on it. The electronics there consisted of a distributor, coil(with wire), sparkplugs (with wires), an alternator and voltage regulator. and for the positioning of the sensor, one could index the old sensor with a sharpie before removal, transfer the mark onto the new one, install it and be reasonably sure they will have a running engine afterwards, provided it ran in the first place, couldn't they?
Trust me when I say, even with my two left hands, consisting of 5 thumbs each, and my half blind eye, anyone that has any mechanical aptitude at all can remove that upper intake. I was so freaked out about it before hand the seals sat in the map pocket of my ex for two weeks, and I didn't buy them until well after my initial post looking for advice.
I have step by step instructions, hard copy, that I can scan for anyone that would like a copy. Just PM me and ask for them, I'll make them into a pdf and send them out, diagrams and all.
