Cam timing confusion | Ford Explorer Forums
rball
Canton, Ohio
'97 xlt
Hi. I'm new to this forum and I'm very confused about the cam timing on the 4.0l sohc engine. I have just replaced the heads on my motor and am starting to set the cams. I have the Haynes manual that seys to set the driver's side cam first, then set the passenger side cam. I also have a download from Autozone that seys to set the driver's side cam, rotate the motor one rotation, then set the passenger side cam. Does anyone know which is right or where I can go to get the correct method.
Thanx in advance
Ryan
