camber kit, 1 or 2? | Ford Explorer Forums
camber kit, 1 or 2?
Clusterpup
Miami, FL
02 Sport Trac 4x4
I understand there is camber adjustment for the drivers side on our trucks. I want to be able to adjust the camber on the passenger side since I did a lift it is visibly off on the passenger side. Can I just install a kit on the passenger side only or do I need to do both sides?
Your better off installing the camber adjusters on both sides in case you ever need it aligned.
Anyone know where I can get the right kit? I see this one at advance auto parts from Moog, Part# K80065
I assume I need to buy a set for each side?
i got mine from napa
Cool, I ordered a set from jcwhitney, will install next weekend, thanks.
