Drivers side camber adjustment? | Ford Explorer Forums
Clusterpup
Miami, FL
02 Sport Trac 4x4
Do our trucks have an adjustment from the factory for the camber on the drivers side? I was told that it did have it but I was going to install a camber kit on the passenger side and I happened to look at the drivers side I didn't see any way to adjust it, it looks the same as the passenger side. If it doesn't have an adjustment I need to order a camber kit for the drivers side as well.
It's my understanding that both sides didn't come with camber adjustment from the factory.
I went ahead and ordered me one more camber kit from JC Whitney and will install over the holidays.
Thanks.
camber kits
This is what I used on both driver and passenger sides. Moog K80065 Cam Bolt Kit I ordered it from amazon. It goes in the upper control arm where it connects to the frame. You'll need two kits. Not too hard to install just be patient and work with it.
If you order from the forum sponsor RockAuto and use the discount code it ends up being really cheap
