mysticclam
Typo King
- April 2, 2004
- Tacoma, WA
- 91 XLT
-.3 to +.8 degrees for a first gen, is this right?
I just put 2 inch lift coils in and took it to be aligned. Had a "bad" wheel bearing that turned out to be just loose. So I have it aligned and the guy says, its done, drives very straight, which it does but the camber is still visibly +
I should have told them to do it over as soon as he said not only did he not need the adjusters, he didnt max out the ones on there, 2 degrees. So now I open up my paperwork and the camber is 2.2 degrees and 1.5 degrees. Gee, thats not in spec, oh I see the computer shows the range should be between -199 degrees and +201 degrees. I guess they just let the computer tell them its in spec and leave it even though it is so obviously not.
