- April 16, 2002
- British Columbia
- 93 4 dr 4x4 manual XL.
I`m confused, my driver`s side camber seems to be out, but it has progressed slowly for many months.
I don`t have left side lean, when I measure things, the wheel wells on each side are dead even. It`s starting to go like this: loo\
I first noticed it a couple months ago, maybe it is that spring sagging a bit and the angle of the tire is keeping that side from being lower?
Or can the camber adjustment move? (I don`t know much about this adjustment system)
Everything is tight, the spindle nut isn`t loose, the tires are on there tight, it doesn`t move if I shake it around, I haven`t really been beating on it and don`t see how anything could be bent.
It`s so confusing.. I was thinking of swapping my coils from side to side, but the fact that my truck is not leaning blows my mind!
-thanks
-thanks
