JBweld won't hold on it I don't think. Solder is your best option, make sure you get the high heat solder. With it blocked it will just cut down the efficentcy of the system. Make sure you get the system vacummed before filling it.
As I mentioned in your other thread...have someone cut the tube there and weld both ends. Common practice. Trying to save that tube will prove nearly impossible.
