mikeinri
- January 18, 2007
- 04 Explorer, 94 XLT (RIP)
Well, you've seen all the warnings about the t-stat, and it's a free country, so why don't you just try it for a week and see what happens? You can always put one back in.
What A/C components did you replace? When was the last time you looked at the front of the condensor? Mine was doing the exact same thing. It has a tranny cooler (stock with the auto trannys) which had leaking rubber hoses (connecting the metal tranny lines under the radiator up to the tranny cooler behind the grille, in front of the condensor). I had so much fluid and road grime there, I probably had no air flow. Since I replaced those rubber tubes and cleaned out the condensor fins, it is 100% better. And yes, I had replaced everything else under the sun before that too.
Hope this helps.
Mike
Hope this helps.
Mike
