Can you identify these wires? | Ford Explorer Forums
sas t4r
denver, colorado
2013 Explorer PIU
hi guys,
So I’m piecing this explorer back together and I found these wires cut on the floor of the driver side rear door. Attached is the pic. There are 2 brown ones, one yellow-green, one blue-white. Does anyone know what they go to?
2013 explorer PIU, but the wiring should be the same for all explorers.
Thanks.
Imgur
Imgur
Does no one have a wiring diagram or anything?
Check out post #21 in this thread where I added a link that may be helpful. I originally found the link using the Forum's 'Search' feature. Factory Power Inverter Install?
Thanks for reply. I have already canvassed that thread before posting mine, but there are no schematics available that detail the wiring in question.
"2013 explorer PIU, but the wiring should be the same for all explorers."
Not true - your ex will be ordered with any number of supplemental wiring packages that differ from civilian units.
With your as-built (wiring prep options in the piu) and the upfitters guide for your year it should be super easy to locate their function.
