Yeah I found that video last night, very helpful. In the video though it appears that he's loosening the castle nut clockwise. Is it reverse threaded? Also curious do new lbj & ubj come greased or do I need to get a grease gun? Also my uppers appear to be stock so from what I've read that the first time around I need to install a whole new unit, control arm and joint as well, is this true? Thanks for all the help out there.
Just look at the new joints. If they come with grease fittings, then you'll need to grease them. They'll have some in them from the factory, but not enough. If you're desperate, they probably have enough grease in them to let you drive to the parts store and get a grease gun, but I wouldn't leave them like that. If they are sealed (no grease fittings), then they are "lubed for life" from the factory; no grease(gun) needed.
As for you're other question: Yes, if you have the original factory uppers, then you either have to buy complete replacements, or buy new uppers with replaceable ball joints. Then, next time, you would only have to replace the ball joints. Be aware, however, that replacing the factory 2-piece right upper w/ any one-piece design (w/ or w/o replaceable ball-joint) means you will lose some of the factory wheel alignment capability. The purpose of the factory 2-piece upper on the right is to allow for further CASTER adjustment, and adjustment of caster-spilt. Caster split affects how the vehicle "tracks" while going down the road. For example, if you mainly travel on roads with a high "crown", caster split can be adjusted, so that it doesn't pull or drift towards the "low side" of the road. However, it would then pull on a flat road (no crown). If you primarily drove on perfectly flat roads, then it could be adjusted for that, but would pull more on a crowned road,etc.... If not adjusted properly, caster-split could also cause the vehicle to require much less effort to turn one way, and much more the other way.
I would stick with the 2-piece upper design, even if it means giving up the replaceable ball joint. I mean, how often are you really going to be doing ball joints?
