Center Hinge Drop Bracket Help | Ford Explorer Forums
yourmoma717
Norfolk, Virginia
92 SPORT
Im finishing my 4" susp. lift, and I cant seem to get this Center hinge bracket to mount right, it is the one towards the rear, and the brackets are made by tuff country, does anyone have an easier way other than grinding this thing down forever?
I am unfamiliar with your lift and bracket.. do you have any pics we could look at to see whats going on?
this might help...is it the one on top...
In your pic the top is the factory brackets, the middle (Superlift??), the bottom is SkyJacker.
it is a factory bracket attached to a tuff country bracket...the pumpkin buster...
Go here http://www.therangerstation.com/tech_library/index.htm. On the right side go to Manufacturer's Instructions. They have lift kit directions for 4 different brands. Not Tough Country, but maybe you can find some applicable info. The brands aren't ALL that different.
thanks for all the help, but just as a little update, i ended up grinding the crap out of the crossmember to make it fit.
