Change Fuel Filter? | Ford Explorer Forums
Change Fuel Filter?
Jarubell
Was Winnipeg, Manitoba now Dartmouth, Nova Scotia, Canada
RIP 92 XLT
331333 kms should I change the fuel filter? Fuel mileage is not so great and i;m sure it has never been changed. How about that fuel pressure regulator, where is it? Is this a common issue?
Don't worry about the FPR. Chane that damn fuel filter though. Get a Motorcraft one. It's inside the frame rail on the drivers side.
Inside a brakcet off of the Radius arm bracket.
PITA to change but if it's never been done do it. You will also need a special tool. Napa or similar can help you with that too.
_________
I went hunting in upper Minnesota-North Dakota near the border and I ended up near Lake Winnipeg. Thats around where you are, right? COLD-COLD-COLD there.
I am near lake Winnipeg. It's cold but this year it has been very mild except for this cold snap we're in for the last couple of weeks
Perfect! Thank you
Perfect! Thank you
Your welcome..
BTW the stickies (threads @ the top of all the forums) contain FAQ type info. So they are a good area to start with when looking for answers..
