springer9861
- March 20, 2004
- Central Ohio
- 91 XL
I took my 91 Explorer over to my dad's garage today and we changed my trans filter and added 6 qts. of mercon atf. Started it up let it warm up and took it for a test drive and my overdrive doesn't work. I can get the explorer up to 65-70 mph and let off the gas and let the rpm's drop to about 1000 then I can step on the gas and it acts like it's in neutral. When the speedo gets to 55 you can step on the gas and it will kick into drive but it will not shift into overdrive. The fluid i drained out didn't smell burnt and it shifted fine before I changed the filter. I have noticed that the shifter pointer doesn't point right to overdrive but just to the left of the O. I can start in 1st and shift it to 2nd then to drive but when the speedo reaches 55 it will not shift into overdrive. Thanks for any and all help...........Larry
