Hank3rd
- September 4, 2003
- NC
- 2000 XLS
I read most of the threads here involving changing the transmission fluid and filter. I decided to only change the fluid that was in the pan and the filter due to exessive mileage, 82k.
Afterwards when I took it for a test drive, I noticed that it did not want to shift from 1st to second gear without releasing the gs pedal. I returned home and added more fluid since it was a little low.
Overall, the trans works fine, but I now noiced that when I irst start the truck up for the day that I have slipping problems. This morning when I left I needed to back up. This was fine, however, when I shifted into drive, the trans did not engage. I had to place in park then drive again. Then there was a little slipping. Not too much though.
I wonder if this is something that will work itself out or maybe loosening all of the crud and removing the aged fluid caused problems.
Has anyone else had this issue?
