Changing brake pads...HELP | Ford Explorer Forums
uiu29
belvidere, il
ranger 1991
It is time to change my brake pads on the ranger (1991). As i took wheel off i was stumped. I have changed many brake pads but this whole system threw me for a loop. Can anyone show me the steps to get this taken care of. My truck sits on jack stands waiting for any help. Thanks in advance.
you have to take the caliper off of the mounting brackets. the brackets bolt up behind the rotor, it has been a while since i changed mine so i dont remember which bolts. Once you get the calipers off you just take the pads out start with the outside one, the one away from the piston. make sure to not strain the break lines too much. to put the pads back in just start with the insid pad first. make sure you put the right side pads on the right side and the left on the left. you bolt everything back up and you are done
