Changing Transmission Oil | Ford Explorer Forums
robbiwan
2002 explorer
I am thinking of changing the transmission oil for my 4.0 v6 XLS. Some questions:
1. Do i need a jack for this or can i just go under the truck since there is
some clearance?
2. What type of motor oil should i use.
3. It is shifting fine should i change the solenoid or the filter?
4. What type of jack should i buy?
5. I am thinking of buying the OTC plug adapter and OTC hand pump.
some clearance?
Yes, floor jack and jack stands
Mercon V
No
3 ton floor works fine for me.
The OTC plug tool worked fine, got mine off amazon.
http://www.amazon.com/OTC-6604-Transmission-Fluid-Adapter/dp/B000JFJMFK/ref=sr_1_1?ie=UTF8&qid=1433533189&sr=8-1&keywords=ford+transmission+fill+adapter&pebp=1433533190463&perid=1Q3N65Q3X0SK0APTV77C
Here is the pump I used,
http://www.princessauto.com/en/detail/plastic-suction-gun/A-p8025521e
some clearance?
Mercon V
No
Thanks so much Tech By Trade!
