changing u joints on my driveshafts??? how to do | Ford Explorer Forums
Lefy
Westchester, NY
98 Sport 4x4 4.0 SOHC
wanna know how to change the u joint or cv joints on my driveshafts
what u joints do i need to replace them what type
as any tips for changing them. thanks
a haynes or chilton does a pretty good job of explaining. So do other threads, I'm sure. And as been discussed MANY times before, the CV-joint is NON-serviceable.. meaning if the CV is bad, ya gotta buy a new shaft,
With the u-joint/ball joint press, it's pretty simple. I want to say that the Spicer 1297 is the u-joint you need (but don't quote me). I do know that Car Quest had the three u-joints I needed for my front driveshaft in stock. Even though they show two different part numbers, they're actually all the same part. Get the u-joints with a zerk fitting. The double cardan joint is kind of a pain. I think there's a distinct order in which to remove/replace the joints but I cannot recall the specific steps. You'll know because some caps won't come out or go in without removing something else.
Hope that was some help - Dave.
Check out the U-joint link in my sig line. It has lots of good info and pics..
