Willard
- March 16, 2007
- Bloomington, Indiana
- 04 Ranger Edge
Ok, so due to problems I was having awhile ago, my explorer has basically a completely new charging system. It has new cables, a new alternator, and a new battery. For the most part everything works fine, always starts great, battery works just as it should.
However, I have a problem with charging sometimes. When I have the headlights and blower fan on, and am stopped and idling in gear (such as at a stoplight) the voltage drops. If the heater fan is on high, it will be enough to dim the lights. I have no other supplementary power items to speak of, except for a little stereo work, which isn't the problem. If I turn the radio off when this happens it has no affect.
So I'm wondering why this is happening. Everything seems to be working fine, it just can't handle the load when I'm stopped. In gear it idles just above 500rpm, where it always has. It runs great.
I'm not sure what I could check that would be causing this. It seems like something is using too much power, or something is holding it back from charging like it should. But with the main components of the charging system all new, it just doesn't make any sense. Battery is the biggest stock one I can get, I believe its 1100 CCA.
Any ideas?
Any ideas?
