Road1
- September 27, 2022
- Sparks, NV
- 2016 FPIU
2017 FPIU
2017 FPIU, 3.7 engine.
A couple of days ago (after cold soaking down into the 10F range), I got an intermitted popup to check the charging system NOW. I was seeing a proper charge on the VOM, but the serpentine belt was showing a puff-out of a couple of fibers, so I replaced it.
I'm still seeing the popup, and now not seeing any charge on the VOM. I charged the battery (12.6VDC) and checked with FORScan, getting P0625:00 and P0658:00.
I have the troubleshooting list and planning to dig into it later today or tomorrow (yep . . .my FPIU is a true Thanksgiving turkey!).
QUESTION 1: I'm assuming that the ring around the negative battery cables is the battery monitor. Am I correct in thinking that the plug on the alternator is only wired to the plug on the battery monitor? That plug is easier to get to than the one on the alternator.
QUESTION 2: Is there a PDF of the schematic for the 2017 FPIU 3.7 online somewhere?
Thanks!
Thanks!
