Cheapest Price for 5.5" Superlift | Page 2 | Ford Explorer Forums
Well, for me looks like I'm going just with 3" body lift, front coil swap with taller ones, add-a-leaf and new shocks. This should give me a total of about 4-5" and that's where I want to be. It'll be enough for what I'm doing. I don't think this whole thing will cost me more then $400.00. For some serious off roading though I would strongly recomend either getting a 5.5" Super or another rig.........
Good luck and show off with your new rides, please!!!!!!!!
:D
adionne - $850 is getting me everything for the "standard" kit which uses drop down brackets for the radius arms. $1050 for the "superrunner" kit (which is what you were quoted for) sounds good. Keep in mind that I would recommend going with the Superrunner kit, and the only reason I am not is because I am going to make my own extended radius arms for even greater flexibility. $450 for labor doesn't sound bad.
tdavis - I'm hoping that I will have this lift at Rubicon, shipping is 7-10 days, if it makes it in 9 I will have it, it it takes 10, I won't. Even though I only have 2.5" of suspension lift right now, I also have 2" body, so at least if I don't have the 5.5" kit installed for Rubicon, I will still have my 33s...
Andre - Sounds like a good choice for you, since you'll be able to run big tires now, and you will still have the option of a big suspension lift later, if you want it. I would definitely recommend buying some lift lips though, because with a 3" body lift and 1" suspension, you will be able to see through your fenders.
Well, it turns out that I am only going to need the rear part of the kit that I ordered, because a local guy is selling me the rest of the lift since he is doing a solid axle swap on his Explorer. I'm pretty excited, since now I am going to get this lift for about $500.
Mat
