Digipixel
- July 12, 2015
- Texas
- 2004 Eddie Bauer Explorer
Hello All
I own a 2004 4.0L V6 Eddie Bauer Explorer. Current Mileage = 111,500 miles.It's has in it the third rebuilt transmission.
Backstory: On July 5th when I started it, I could hear the alternator whining AND the 'Check charging system' warning pops up AND the red battery light flashes. On July 6th, I take it too a Starter and Alternator rebuild shop nearby. I watched the owner disassemble the ALT and showed me where a diode on the diode bridge was scorched/broken. He cleaned all the parts and rebuilt the ALT with two new shaft bearings, new diode bridge and new voltage regulator. He then bench tested the rebuilt unti where I watched the output at 13.8 V at 125 amps. I carefully re-attached all wires and connectors, cleaned the battery terminals and cables.
Today (7/12/2015), once again the system warning center flashes 'Check Charging System' and the red battery indicator light blinks. I take it to O'Reillys and the very nice tech attaches the battery tester. The battery passes the 625 CCA test no problem. He has me start the car with ALL systems turned off, meaning no AC/radio/lights - the car just idles - ALT passes the test. He then has me turn on AC/FAN/Lights, etc; diodes read fine but the voltage regulator test fails. The battery/ALT tester reads the operating voltage when all items are turned on, and it read 12.59 volts on the battery terminals. This matches precisely the voltage I read with my digital volt meter.
Any assistance and suggestions are greatly appreciated.
Sincerely - Digipixel.
