Aurrick
- August 30, 2006
- Nor Cal
- '01 Ranger Edge 4x4
CEL came on and stayed on. I cleared it by disconnecting the battery for 5 minutes. It stayed off for about 30 miles and came back on.
Autozone's code reader gave one code only: P0402 "EGR Flow Excessive".
The autozone guy said that I needed to replace the EGR valve and clean out the line that leads from the valve to the exhaust. Does this sound correct?
It seems counterintuitive to me. If the EGR flow is excessive, doesn't that mean that too much is flowing through the valve and the line? If the line was clogged with carbon deposits wouldn't the flow be low, not excessive?
2001 Ford Ranger Edge 4x4
4.0L SOHC
57,430 miles
I use regular unleaded 87 Octane, no aftermarket additives.
If replacing the valve is the right way to go, is there anything I have to do besides just put the new valve in? Any adjustments?
Thanks for your help.
Aurrick
4.0L SOHC
57,430 miles
Aurrick
