Seaeric
- December 27, 2006
- Ft Lauderdale, Fl.
- 97 XLT
I have a 1997 2WD Explorer with the 4L V6 SOHC, 87,000 miles. So I went to Auto Zone and had them read the code. I don't have the print out in front of me but the code was like 445 or similar, which is massive air/vacuum leak in the fuel system. First problem was suggested was what I already thought which was that the gas cap had not been on tight. There was a few other possible causes on the print out like vacuum line disconnected etc. but fuel cap is the one I suspected anyway. The kid at AZ said it was against the rules for him to clear the code for me, that I had to take it to a shop and get it checked out. I'm away from home and in unfamiliar territory so I figured perhaps the easiest alternative was the Ford dealer. They tell that their computer said it had some sort of bad valve in the emissions system. $150. part (which is not in stock they have to get it) and 3 hours labor. To me, (an obvious mechanical neophyte) the AZ code diagnosis and the Ford Dealer proposed repair sound WAY different. Am I having a logic attack, or am I getting screwed by the dealer?
