LEFT BANK LEAN RIGHT BANK LEAN ... what this means: there is an oxygen sensor on both sides of the exhause manifold, hence right bank and left bank, both are reading lean, meaning your oxygen sensors most likely need replaced, lucky for you both came up.. on some cars the code only reads bad o2 sensor, not which bank.. i run obd scans every day, its not that bad, youll just get piss poor as mileage
