CHeck engine Light | Ford Explorer Forums - Serious Explorations
CHeck engine Light
insanejosh
Hi recently my check engine light has come on and it is giving me the code P1130 on my 2002 ford explorer sport
I've changed the maf sensor, spark plugs and wires, and the fuel filter. I'm thinking it might be a vacuum hose, but can't find a diagram anywhere, to check to see if it might be that.
If anyone could help me out here it would be greatly appreciated.
You know, I need to look into that some more, but if I recall, that's more from a lack of crosscounts than anything. That can be from a dead rich or lean (which could be a vacuum leak) condition, or a bad sensor. You will need to read the sensor and check. I believe it's bank 1
Ya i asked the local mechanic around here, and they actually had a ford in there that had the same code, and it ended up just being the fuel filter. But i'm trying to do more research on it to try and figure this one out.
