I drove to Harrisburg, Pa this weekend with new FPR in a box in the back awaiting the help of my girlfriend's father to install. The night before I cleaned the MAF just in case that was the culprit. Hit the road and 40 miles down the road CHECK ENGINE. Stopped to eat, got 20 miles down the road CHECK ENGINE. Here is where it gets interesting, I was then positive it was the FPR. When we left the restaurant we got 100+ miles away with no check engine...then it came on and remained on until we pulled into Pa. Total trip is 400 miles.
This morning we took the old FPR off following directions from the Explorer fixit bible web page (cant remember the address but will post later). Kudos to everyone who submits to that page as the directions were right on for what to do. Depressurized the tank, rigged the hoses for AC out of the way, drained coolant and removed hose, removed air hose. The FPR was a little difficult to unbolt but once it was undone it popped out of the engine. Note: The main gas line going in has a cap around it, we proke a prong taking it off because we weren't sure what it was. Then the gas line is attached metal to metal, with a safety (you can push it into the fuel line, but you can't easily pull it out). Anyone who has done this knows what I mean, we used pliers, screw drivers, and small crow bar and it finally popped off. New FPR from carparts.com ($49) went on easily, tightened bolts and replaced all the hoses and fluid. Put the fuel relay back in place and she fired right up. The Explorer runs fine (not that it wasnt before) the true test will be our journey home...will the mysterious CHECK ENGINE reappear???? Tune in Monday to find out....
